Protective coating of fiberglass canopy for '88 Bronco
A brief check in from a first time user: On my weathered and heavily oxidized fiberglass canopy, as instructed over the phone and on the info sheets, I applied the Aqua-Kleen, then the Rust Blast, followed by 2-coats of Rust Seal. When dry, I will apply 2-coats of the Top Coat. Surprised to note a limited area of non-adhesion (fish-eye, perhaps?) despite the topical preparation without any abrasive prep. I'm hoping a light sanding will prepare an optimal bonding surface for the Top Coat. Any suggestions? Many thanks.
You are doing correct. Give the RustSeal a light sand and the topcoat should adhere perfectly.
