April 27, 201016 yr comment_2044 I have a 1996 water cooled Honda shadow sabre 1100. There is a small leak or a crack on the engine. I can´t see where it is so I have to take the covering parts off first. I am in guatemala and need a permanant fix. Will the putty work or should I use something else? Any suggestions? Link to comment https://success.kbs-coatings.com/topic/1413-motorcycle-engine/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
April 28, 201016 yr comment_2346 I know people who have used the NuMetal Epoxy Putty to fix a crack in an engine. The NuMetal Epoxy Putty withstands temps up to 300°F Here is more information for you: http://www.kbs-coatings.com/KBS-NuMetal-Epoxy-Putty_p_9-19.html Link to comment https://success.kbs-coatings.com/topic/1413-motorcycle-engine/#findComment-2346 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
