gas cap bung
can you use the NuMetal epoxy to install a motorcycle gas cap bung instead of welding it in? the reason i ask is i am going to clean and seal the tank with KBS products,but the bung will not allow me to drain the tank properly.therefore i would like to seal the tank first and then install the bung without welding
