SURFCE TREATMENT
Are you talking about the existing paint on the outside of the tank has bubbled?
Did you seal the inside of the tank?
  • Author
Tank has been sealed, stripped & sealed again, tank was then repainted, base coat & 2 pack clear & it has bubbled through the paint, one tiny spot in the bottom corner of the tank & several bubbles at the top.
I have carefully cut the paint back in these areas & want to treat with something that won't react to fuel & then repaint.
Thanks for your help. Roy............
Yes. Coat that area with the 3 Step System (AquaKlean, RustBlast and RustSeal).
