February 5, 201016 yr comment_2029 I read the section on Rustseal color choice on the website but I thought I would post the question to be sure I dont misunderstand. Is there a real durablity difference between the different colors? And if so, could you please elaborate? My application will be on an indoor high traffic motorcycle hydraulic lift, so it would have the usual tools, parts, and mild chemicals exposure on it. I'm partial to the gloss black but would gladly sacrifice color, for durablity. The lift is 1/4" steel diamond plate that measures 7'x2', and I'd like to coat the top with 2-3 coats,( is 2 coats enough?) and the bottom with one coat. Will a pint will cover 56 sq ft? Any advice would be greatly appreciated. Thanks Link to comment https://success.kbs-coatings.com/topic/1398-a-question-about-rustseal-colors-and-durablility/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
February 8, 201016 yr comment_2313 All RustSeal is made with the same resin, so it is all extremely durable and tough. If you are looking for better abrasion resistance, you could go with the Galvanized Steel, the Oxide Red, the Guardian Green of the Silver colors. But like I said, all of the colors are very durable and very tough. You can find complete instructions for RustSeal here: http://www.kbs-coatings.com/RustSeal-Information-and-Instructions_ep_38-1.html You can also find the Fix-It Guide which will help you quickly identify the causes of and the recommended solutions for the most common issues that could occur with RustSeal here: http://www.kbs-coatings.com/fix-it-guide-rustseal.html You can also find Instructional Videos here: http://www.kbs-coatings.com/KBS-Videos_ep_90-1.html You can also find a Flow Chart for using the KBS 3 Step System here: http://www.kbs-coatings.com/Flow-Chart--RustSeal-on-Steel_ep_87-1.html Link to comment https://success.kbs-coatings.com/topic/1398-a-question-about-rustseal-colors-and-durablility/#findComment-2313 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
