December 27, 200916 yr comment_2024 hi i was removing some paint today and removed some of the rustseal on another panel i found that the panel under the paint was all rusted again should i remove the rust seal and start again or should i not be worried? i know that rust seal will treat some of the rust Link to comment https://success.kbs-coatings.com/topic/1393-rust-under-rustseal/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
December 28, 200916 yr comment_2298 How were you removing the paint? How did you apply the RustSeal? Link to comment https://success.kbs-coatings.com/topic/1393-rust-under-rustseal/#findComment-2298 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
December 29, 200916 yr Author comment_2299 when i was doing that section i was only using a wire brush on a drill i aplied the rust seal with a brush now i am using i think it is nylon brushes on the dril so it is removing the rust more this time Link to comment https://success.kbs-coatings.com/topic/1393-rust-under-rustseal/#findComment-2299 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
December 29, 200916 yr comment_2300 You will want to wire wheel it all down to the bare metal and then use the KBS 3 Step System of AquaKlean, RustBlast and RustSeal. You can find complete instructions for RustSeal here: http://www.kbs-coatings.com/RustSeal-Information-and-Instructions_ep_38-1.html You can also find the Fix-It Guide which will help you quickly identify the causes of and the recommended solutions for the most common issues that could occur with RustSeal here: http://www.kbs-coatings.com/fix-it-guide-rustseal.html You can also find Instructional Videos here: http://www.kbs-coatings.com/KBS-Videos_ep_90-1.html You can also find a Flow Chart for using the KBS 3 Step System here: http://www.kbs-coatings.com/Flow-Chart--RustSeal-on-Steel_ep_87-1.html Link to comment https://success.kbs-coatings.com/topic/1393-rust-under-rustseal/#findComment-2300 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
December 30, 200916 yr Author comment_2303 ohh damn i need to wire wheel most of the car down now to find out what areas are rusted the whole inside of the car has been coated aswell i waited till the rust started to go a bit white in colour so i thought the rust seal would work over it oh well thanks for the help though Link to comment https://success.kbs-coatings.com/topic/1393-rust-under-rustseal/#findComment-2303 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
December 30, 200916 yr comment_2304 Your welcome. Please let us know if we can help you in any other way. Link to comment https://success.kbs-coatings.com/topic/1393-rust-under-rustseal/#findComment-2304 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
