December 26, 200916 yr comment_2023 Hello there I have a old steel railing at my home which I had sand blasted and painted over may times but it still rust after some time. What products and methods should I use to clean and paint over the railing so it will not rust for a few years. Thanks Link to comment https://success.kbs-coatings.com/topic/1392-old-steel-railings/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
December 28, 200916 yr comment_2297 Is the surface sand blasted right now? Or will you be going over paint? Link to comment https://success.kbs-coatings.com/topic/1392-old-steel-railings/#findComment-2297 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
January 7, 201016 yr Author comment_2306 The surface still has old paint and rust on it. I am planing to sand blst and repaint the rialings. Link to comment https://success.kbs-coatings.com/topic/1392-old-steel-railings/#findComment-2306 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
January 8, 201016 yr comment_2307 If you are sandblasting, then apply 2 coats of RustSeal and a top coat of your choice. You can find complete instructions for RustSeal here: http://www.kbs-coatings.com/RustSeal-Information-and-Instructions_ep_38-1.html You can also find the Fix-It Guide which will help you quickly identify the causes of and the recommended solutions for the most common issues that could occur with RustSeal here: http://www.kbs-coatings.com/fix-it-guide-rustseal.html You can also find Instructional Videos here: http://www.kbs-coatings.com/KBS-Videos_ep_90-1.html You can also find a Flow Chart for using the KBS 3 Step System here: http://www.kbs-coatings.com/Flow-Chart--RustSeal-on-Steel_ep_87-1.html Link to comment https://success.kbs-coatings.com/topic/1392-old-steel-railings/#findComment-2307 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
