December 2, 200916 yr comment_2020 Have modified a sump to fit 186 boat motor and was going to use gold standard fuel tank sealer to cover welds. Will this work with the heat? Link to comment https://success.kbs-coatings.com/topic/1389-boat-sump/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
December 2, 200916 yr comment_2292 Gold Standard Tank Sealer will withstand heat of up to 500 Degrees Fahrenheit. Link to comment https://success.kbs-coatings.com/topic/1389-boat-sump/#findComment-2292 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
December 30, 200916 yr Author comment_2302 Used the sealer 1 week ago as per instructions, only thing was I could not get all the sealer outbefore curing and in doing so has created some runs/ridges through the middle of the sump,that still seem soft to press. what problems, if any, do I face, and if so solution? Link to comment https://success.kbs-coatings.com/topic/1389-boat-sump/#findComment-2302 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
January 4, 201016 yr comment_2305 Let them cure for a while and they should harden up. Link to comment https://success.kbs-coatings.com/topic/1389-boat-sump/#findComment-2305 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
