November 27, 200916 yr comment_2019 hello, do I understand correctly that a newly sandblasted chassis could be coated with rustseal without using the first 2 steps of the 3 step process? Link to comment https://success.kbs-coatings.com/topic/1388-sandblasted-chassis/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
November 30, 200916 yr comment_2291 Absolutely, just blow off the sand dust and begin application. Sandblasting leaves a clean textured surface which allows for great adhesion. Link to comment https://success.kbs-coatings.com/topic/1388-sandblasted-chassis/#findComment-2291 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
September 14, 201016 yr comment_2373 Out of curiosity, would using the first 2 steps on a sandblasted surface make RustSeal work even better? Or no? Link to comment https://success.kbs-coatings.com/topic/1388-sandblasted-chassis/#findComment-2373 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
September 15, 201016 yr comment_2379 It is not recommended to use the AquaKlean and RustBlast on freshly sandblasted steel. It is best to blow off the sand residue with clean air and then apply the RustSeal. You can find complete instructions for RustSeal here: http://www.kbs-coatings.com/RustSeal-Information-and-Instructions_ep_38-1.html You can also find the Fix-It Guide which will help you quickly identify the causes of and the recommended solutions for the most common issues that could occur with RustSeal here: http://www.kbs-coatings.com/fix-it-guide-rustseal.html You can also find Instructional Videos here: http://www.kbs-coatings.com/KBS-Videos_ep_90-1.html You can also find a Flow Chart for using the KBS 3 Step System here: http://www.kbs-coatings.com/Flow-Chart--RustSeal-on-Steel_ep_87-1.html Link to comment https://success.kbs-coatings.com/topic/1388-sandblasted-chassis/#findComment-2379 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
