November 9, 200917 yr comment_2016 Hi: just got the motorcycle tank kit and followed the directions to the letter. My question is: when I look into the tank I see 2 bad rust spots that don't seem to dry. They appear waxy almost. The rest of the interior of the tank looks super, almost galvanized! I should note that I soldered the bad rust holes from the outside of the tank before I proceed with the cleaning. I supose it is possible that the waxy spots I see are residual flux from the soldering process. I dried the interior of the tank wit forced air cool and heated for about 6 hours and I assure you it is dry. How should I proceed with the spots. I'm ready to seal the tank but don't want a coating failure at this point in the project. Help Link to comment https://success.kbs-coatings.com/topic/1385-2-waxy-rust-spots/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
November 10, 200917 yr comment_2276 It sounds just like you've described with the flux. Do you have any more AquaKlean left? Can you reach those areas with a brush of some kind? Link to comment https://success.kbs-coatings.com/topic/1385-2-waxy-rust-spots/#findComment-2276 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
November 10, 200917 yr Author comment_2277 Just some of the old stuff I drained out. Do you think that still has some cleaning properties and do you think it needs to be removed for the tank sealer to stick? Link to comment https://success.kbs-coatings.com/topic/1385-2-waxy-rust-spots/#findComment-2277 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
November 11, 200916 yr comment_2278 Yes. You will want to get that out so that the Gold Standard Tank Sealer can adhere properly and give you the long lasting protection that you desire. Link to comment https://success.kbs-coatings.com/topic/1385-2-waxy-rust-spots/#findComment-2278 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
November 11, 200916 yr Author comment_2279 Do you think the used product will still work or should I get some fresh cleaner and etcher? Would scrubbing it with a parts cleaning brush, not an easy task, help? Link to comment https://success.kbs-coatings.com/topic/1385-2-waxy-rust-spots/#findComment-2279 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
November 11, 200916 yr comment_2280 The RustBlast should still work. The AquaKlean should still work as well as long as it is not too dirty. Yes, you will want to scrub it with a parts cleaning brush. Link to comment https://success.kbs-coatings.com/topic/1385-2-waxy-rust-spots/#findComment-2280 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
November 11, 200916 yr comment_2281 I worry that the sealer would not adhere properly to those areas. I would recommend some more cleaner & etch, and a strong solution 1:1 of the cleaner with hot water and a GOOD long soaking of that area. Any manual scrubbing of the area would definitely help. Then rinse and etch as normal before sealing. That flux can indeed be tough to remove. Link to comment https://success.kbs-coatings.com/topic/1385-2-waxy-rust-spots/#findComment-2281 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
November 11, 200916 yr Author comment_2282 Will the aqua clean remove the zinc coating from the blaster? Will I need to re-etch the entire tank or just the two spot that I scrub to remove the wax? Link to comment https://success.kbs-coatings.com/topic/1385-2-waxy-rust-spots/#findComment-2282 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
November 12, 200916 yr comment_2283 Yes. It would be best to re-etch the surface with RustBlast. Link to comment https://success.kbs-coatings.com/topic/1385-2-waxy-rust-spots/#findComment-2283 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
November 13, 200916 yr Author comment_2284 How clean does the rustblast need to be? I pored it out in a kind of dirty bucket, a bit of oil residue on the bottom. Link to comment https://success.kbs-coatings.com/topic/1385-2-waxy-rust-spots/#findComment-2284 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
November 13, 200916 yr Author comment_2285 I'm still not happy with the two spots. I gave it a 24 hr soak and scrubbed it every couple hours with a parts brush and it still doesn't look clean to me. Perhaps a wire brush? Link to comment https://success.kbs-coatings.com/topic/1385-2-waxy-rust-spots/#findComment-2285 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
November 13, 200916 yr comment_2286 Yes. Go ahead and hit it with the wire brush. Link to comment https://success.kbs-coatings.com/topic/1385-2-waxy-rust-spots/#findComment-2286 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
November 13, 200916 yr Author comment_2287 I'll try the wire brush. I ordered fresh chemicals so I'll start over again. Scrub, Clean, and Etch. I don't want to do this twice! Link to comment https://success.kbs-coatings.com/topic/1385-2-waxy-rust-spots/#findComment-2287 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
November 16, 200916 yr comment_2288 Sounds like a great plan. Link to comment https://success.kbs-coatings.com/topic/1385-2-waxy-rust-spots/#findComment-2288 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
