November 4, 200917 yr comment_2014 Hi i am in the process of coating a whole car with your products such as rust seal and top coat i would just like to know about the grounding points on the vehicle i can sand the areas down but i would think that those areas will rust could you please advise me on how to tackle this thanks Link to comment https://success.kbs-coatings.com/topic/1383-grounding-points/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
November 5, 200917 yr comment_2269 Just grind off the RustSeal, make your connections. The beauty of the RustSeal is it will not allow the rust to creep beyond the area. You can also apply some dielectric grease to the area. You can find complete instructions for RustSeal here: http://www.kbs-coatings.com/RustSeal-Information-and-Instructions_ep_38-1.html You can also find the Fix-It Guide which will help you quickly identify the causes of and the recommended solutions for the most common issues that could occur with RustSeal here: http://www.kbs-coatings.com/fix-it-guide-rustseal.html You can also find Instructional Videos here: http://www.kbs-coatings.com/KBS-Videos_ep_90-1.html You can also find a Flow Chart for using the KBS 3 Step System here: http://www.kbs-coatings.com/Flow-Chart--RustSeal-on-Steel_ep_87-1.html Link to comment https://success.kbs-coatings.com/topic/1383-grounding-points/#findComment-2269 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
