October 13, 200917 yr comment_2010 Can I use the tank sealer with an aluminium tank and do I just follow the same instructions as for a steel tank? Will the tank sealer react to methanol fuel? Link to comment https://success.kbs-coatings.com/topic/1379-aluminum-motorcycle-tank-sealer/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
October 13, 200917 yr comment_2259 Yes. It will work on an Aluminum Tank. The Instructions are the same. You can find complete instructions for the Gold Standard Gas Tank Sealer here: http://www.kbs-coatings.com/Gold-Standard-Tank-Sealer-Information-Instructions_ep_39-1.html You can also find the Fix-It Guide which will help you quickly identify the causes of and the recommended solutions for the most common issues that could occur with Tank Sealer here: http://www.kbs-coatings.com/fix-it-guide-tank-sealer.html You can also find Instructional Videos here: http://www.kbs-coatings.com/KBS-Videos_ep_90-1.html You can also find Tank Sealer Flow Charts here: http://www.kbs-coatings.com/Flow-Chart--Tank-Sealer_ep_88-1.html Link to comment https://success.kbs-coatings.com/topic/1379-aluminum-motorcycle-tank-sealer/#findComment-2259 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
