September 20, 200917 yr comment_2007 I recently order a motorcycle tank kit. I cleaned the tank out with the Aqua clean and let dry. This actually did a good job and a lot of loose rust was washed out leaving quite a bit of bare metal visible. I then used the rust blast for about 30 minutes. I rinsed it as thouroughly as possibly and let it dry. A rust like coating formed over most of the surfaces even the ones that were clean after the Aqua clean. Some of this can be rubbed off. How should I proceed before using the rust seal? cheers Link to comment https://success.kbs-coatings.com/topic/1376-motorcycle-tank-kit/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
September 21, 200917 yr comment_2254 Here is a link to the instructions: http://www.kbs-coatings.com/RustSeal-Information-and-Instructions_ep_38-1.html It is not necessary to remove every last bit of rust before applying RustSeal. RustSeal is very capable of bonding to & permanently sealing any remaining flash rust or corrosion. After treatment with RustBlast, a slight white powder residue may appear. This is a zinc phosphate coating advantageous for RustSeal adhesion. Items treated with RustBlast can remain uncoated for up to 30 days depending on environmental conditions. Link to comment https://success.kbs-coatings.com/topic/1376-motorcycle-tank-kit/#findComment-2254 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
September 21, 200917 yr comment_2255 As long as you have followed the instructions, you will want to proceed with RustSeal. Link to comment https://success.kbs-coatings.com/topic/1376-motorcycle-tank-kit/#findComment-2255 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
