June 26, 200917 yr comment_1993 My refrigerator is filled with rust spots on the inside of the door where the plastic seal goes around. The seal is also filled with rust. Will rustseal be able to cover the rust or just coat it so no more rust will emerge? Link to comment https://success.kbs-coatings.com/topic/1362-refrigerator/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
June 26, 200917 yr comment_2236 You can use the System Sampler: http://www.kbs-coatings.com/KBS-System-Sampler-Kit_p_23.html Make sure it is bone dry before the RustSeal Step. Also, make sure it is completely dry before you put it back in service. You can find complete instructions for RustSeal here: http://www.kbs-coatings.com/RustSeal-Information-and-Instructions_ep_38-1.html You can also find Instructional Videos here: http://www.kbs-coatings.com/KBS-Videos_ep_90-1.html You can also find a Flow Chart for using the KBS 3 Step System here: http://www.kbs-coatings.com/Flow-Chart--RustSeal-on-Steel_ep_87-1.html Link to comment https://success.kbs-coatings.com/topic/1362-refrigerator/#findComment-2236 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
