June 26, 200917 yr comment_1992 I intend to cover the underside of my newly installed galvanized floorboards w/ Herculiner. The rest of the undercarriage will be coated w/ KBS rust seal then the herculiner. Should I use the rust seal over the floorboards as well? I intend to sandblast the rest of the undercarriage. Should I do the same to "etch" the galvanized steel? Or, how would I get the best results? Link to comment https://success.kbs-coatings.com/topic/1361-floorboards/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
June 26, 200917 yr comment_2235 "Should I use the rust seal over the floorboards as well?" Yes. That would be best. "Should I do the same to "etch" the galvanized steel? Or, how would I get the best results? " Yes. That would also be best. Link to comment https://success.kbs-coatings.com/topic/1361-floorboards/#findComment-2235 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
