June 26, 200917 yr comment_1991 i have a new boat trailer and am interested in making sure it does not rust. what would you recommend? Link to comment https://success.kbs-coatings.com/topic/1360-boat-trailer/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
June 26, 200917 yr comment_2230 Do you have a factory coating on there? If so, the best way would be to get rid of the factory coating by blasting it or wire wheeling it all off. If you sandblast, you will want to apply 2-3 coats of RustSeal and then a UV Stable Top coat such as our BlackTop. If you do not sandblast, you will use the KBS 3 Step System of AquaKlean, RustBlast and RustSeal followed by a UV Stable Top coat such as our BlackTop. You can find complete instructions for RustSeal here: http://www.kbs-coatings.com/RustSeal-Information-and-Instructions_ep_38-1.html You can also find Instructional Videos here: http://www.kbs-coatings.com/KBS-Videos_ep_90-1.html You can also find a Flow Chart for using the KBS 3 Step System here: http://www.kbs-coatings.com/Flow-Chart--RustSeal-on-Steel_ep_87-1.html BlackTop can be found here: http://www.kbs-coatings.com/BlackTop-Chassis-Paint_p_35.html Link to comment https://success.kbs-coatings.com/topic/1360-boat-trailer/#findComment-2230 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
June 26, 200917 yr Author comment_2231 Its a brand new trailer with powdercoat paint. I would prefer not to remove the paint. I want to protect it, if possible. Any suggestions? Link to comment https://success.kbs-coatings.com/topic/1360-boat-trailer/#findComment-2231 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
June 26, 200917 yr comment_2232 Yes. Clean it with AquaKlean, sand it down, and apply 2-3 coats of RustSeal and then a UV Stable Top coat such as our BlackTop. Link to comment https://success.kbs-coatings.com/topic/1360-boat-trailer/#findComment-2232 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
June 26, 200917 yr Author comment_2233 Can I simply put the blacktop over existing paint rather than repainting with rustseal? Link to comment https://success.kbs-coatings.com/topic/1360-boat-trailer/#findComment-2233 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
June 26, 200917 yr comment_2234 Yes. Using RustSeal and then BlackTop would be best, but you can just apply the BlackTop if you choose. Link to comment https://success.kbs-coatings.com/topic/1360-boat-trailer/#findComment-2234 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
