June 22, 200917 yr comment_1990 I have a 1952 FX Holden I am restoring. I am replacing the outer sill panels as they are moderately rusted, with some small holes. I planned on coating the inner sill surfaces with rust seal. My question is, do you have any thought/suggestions re coating the welded inner portions of the panels? I had thought of using a spray nozzle & accessing the inside of the sill through some holes drilled through the inner sill panel, much in the manner of rust proofing practice. These holes would them be sealed with rubber plugs. While this is not necessarily a 'perfect' solution, it's the best I can think of at present. Any ideas would be appreciated. Ray Link to comment https://success.kbs-coatings.com/topic/1359-rust-seal-welding-question/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
June 22, 200917 yr comment_2227 You could use the Underseal Spray Gun and Probe. You can find it here: http://www.kbs-coatings.com/Underseal-Spray-Gun-amp-Probe_p_37.html Let us know if you think that will work. Link to comment https://success.kbs-coatings.com/topic/1359-rust-seal-welding-question/#findComment-2227 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
June 22, 200917 yr Author comment_2228 That looks perfect. Thanks. Is this product available in Oz, or is it US only purchase? Link to comment https://success.kbs-coatings.com/topic/1359-rust-seal-welding-question/#findComment-2228 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
June 22, 200917 yr comment_2229 Please email [email protected] for availability in Oz. Link to comment https://success.kbs-coatings.com/topic/1359-rust-seal-welding-question/#findComment-2229 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
