June 15, 200917 yr comment_1988 I have a vintage car engine with an aluminium crankcase and sump and I have had these pressure cleaned to as new condition. I want to paint the inside of these to seal them. Will any of your products do this job and be ok in the oil and heat? Link to comment https://success.kbs-coatings.com/topic/1357-painting-inside-engine/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
June 16, 200917 yr comment_2223 Yes. Use the KBS 3 Step System. It is fine with that oil and heat up to 600 degrees. Make sure you get the surface really, really clean with the AquaKlean (the 1st step in the 3 Step System). You can find complete instructions for RustSeal here: http://www.kbs-coatings.com/RustSeal-Information-and-Instructions_ep_38-1.html You can also find Instructional Videos here: http://www.kbs-coatings.com/KBS-Videos_ep_90-1.html Link to comment https://success.kbs-coatings.com/topic/1357-painting-inside-engine/#findComment-2223 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
