June 15, 200917 yr comment_1987 I am going to paint an old 12' aluminum boat, how will the Rust Seal work on this application? will it help seal the rivets that are a little leaky? Thanks Link to comment https://success.kbs-coatings.com/topic/1356-aluminum-boat/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
June 15, 200917 yr comment_2222 Will it be sandblasted? If so, you can apply 3 coats or more of the RustSeal and then topcoat if necessary (if it will be consistently exposed to UV rays). If not, you will want to use the complete KBS 3 Step System (AquaKlean, RustBlast & RustSeal). And then topcoat if necessary (if it will be consistently exposed to UV rays). It should seal your leaky rickets as long as they are not too bad. You can find complete instructions for RustSeal here: http://www.kbs-coatings.com/RustSeal-Information-and-Instructions_ep_38-1.html You can also find Instructional Videos here: http://www.kbs-coatings.com/KBS-Videos_ep_90-1.html Link to comment https://success.kbs-coatings.com/topic/1356-aluminum-boat/#findComment-2222 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
