June 1, 200917 yr comment_1982 Can you tell me the amount of Aquaklean, Rustblast and Gold sealer I would need for this size tank. Also exterior coating recommendations. This is a baffled tank and has corrosion on the outside to go along with a pin hole in one corner. I plan to tig weld the corner after cleaning. Do you see any problems with this? Just don't want to blow myself up after cleaning. Link to comment https://success.kbs-coatings.com/topic/1351-44-gallon-aluminum-boat-fuel-tank/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
June 1, 200917 yr comment_2210 You will want to get: 1 Gallon of AquaKlean: http://www.kbs-coatings.com/KBS-AquaKlean_p_27.html 1 Gallon of RustBlast: http://www.kbs-coatings.com/KBS-RustBlast_p_29.html 2 Quarts of Gold Standard Tank Sealer: http://www.kbs-coatings.com/Gold-Standard-Tank-Sealer_p_30.html You will want to clean the tank first and then weld. You are correct. You can find complete instructions for the Gold Standard Gas Tank Sealer here: http://www.kbs-coatings.com/Gold-Standard-Tank-Sealer-Information-Instructions_ep_39-1.html You can also find Instructional Videos here: http://www.kbs-coatings.com/KBS-Videos_ep_90-1.html Link to comment https://success.kbs-coatings.com/topic/1351-44-gallon-aluminum-boat-fuel-tank/#findComment-2210 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
June 2, 200917 yr Author comment_2211 Thanks for the fast response. I will be placing my order. I will post updates once the project is completed. I have already got a second tank to do and I haven't even done mine yet. Oh, if no response again I blew up and can't type anymore. Something about welding on a feul tank scares me. Thanks again. Link to comment https://success.kbs-coatings.com/topic/1351-44-gallon-aluminum-boat-fuel-tank/#findComment-2211 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
June 2, 200917 yr comment_2213 Watch the second Tank Sealer video here: http://www.kbs-coatings.com/KBS-Videos_ep_90-1.html .. the guy welds his tank. Just make sure you have cleaned it first with the AquaKlean. That will get our the fumes. Link to comment https://success.kbs-coatings.com/topic/1351-44-gallon-aluminum-boat-fuel-tank/#findComment-2213 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
August 14, 200917 yr Author comment_2250 The last video was good for me and the tank has been now done for almost a week. The aquaklean was just as stated. After I cleaned it you couldn't tell if it had fuel in it or water. After that it was tig welded and the rest is easy as pie. The tank is ready to be put back into service. Thanks again. Link to comment https://success.kbs-coatings.com/topic/1351-44-gallon-aluminum-boat-fuel-tank/#findComment-2250 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
August 19, 200916 yr comment_2251 Thanks for your feedback. We really appreciate you taking the time to let us know how it worked for you. Link to comment https://success.kbs-coatings.com/topic/1351-44-gallon-aluminum-boat-fuel-tank/#findComment-2251 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
