April 26, 200917 yr comment_1972 I think I applied under humidity that was slightly too high. I have very small bubbles in the finish and I would like to find out what I need to do here. Hoping I do not have to strip and start over. this was just the first coat. I plan on putting 3 coats down, then followed by Blacktop. Also, how long MAX should I wait between coats of rustseal? I have limited time to work on this project and will probably be giving coats every night until done. Thanks Ryan Link to comment https://success.kbs-coatings.com/topic/1341-bubbles-in-first-coat/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
April 27, 200917 yr comment_2182 Ryan -- You can give the RustSeal a sand to get rid of the bubbles and then go over it with another coat of RustSeal. Doing coats every night should be fine for you. Please let us know if you have any other questions. Link to comment https://success.kbs-coatings.com/topic/1341-bubbles-in-first-coat/#findComment-2182 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
April 27, 200917 yr Author comment_2183 Thanks very much Link to comment https://success.kbs-coatings.com/topic/1341-bubbles-in-first-coat/#findComment-2183 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
