November 28, 200817 yr comment_1874 I coated a bike tank last year and this year I am sending the tank out for powder coating. My question is how will the tank sealer hold up. The tech told me the tank will be heated to 400 degrees. I'm concerned that I will have to remove the lining job I did last year. Link to comment https://success.kbs-coatings.com/topic/1243-powder-coating-a-sealed-tank/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
October 20, 201412 yr Author comment_3072 In general, our Tank Sealer holds up under the powder coating process. However, if you have the choice, it is always best to do the powder coating process first and then do the KBS 3 Step Tank Sealing System to seal up the inside of the tank. Link to comment https://success.kbs-coatings.com/topic/1243-powder-coating-a-sealed-tank/#findComment-3072 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
