May 18, 200818 yr comment_1665 I need to do the eintire underside of my car. It is on a rotissorie but is too large to do all at once and keep the rust blast wet for 30+ minutes. If I do half at a time when I rinse the second half will the water from rinsing that gets on the first half harm it? Thanks in advance! Link to comment https://success.kbs-coatings.com/topic/1034-large-areas/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
February 19, 201511 yr comment_3127 That will work great for you. You may get some slight flash rust, but you can safely paint the RustSeal over it after the entire area has been rinsed clear and allowed to completely dry. Please check out the complete directions for RustSeal HERE. Link to comment https://success.kbs-coatings.com/topic/1034-large-areas/#findComment-3127 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
