Showing results for tags 'gas tank sealer'.
    • KBS MAXX Clear
    • KBS Top Coater 1K Aerosol
Found 5 results
  1. When treating a large steel diesel tank, such as in a boat, all the rust is at the bottom when water will lie. It is impossible to treat the interior of such a tank with 100% confidence of no gaps, when working through an access hole. What surface preparation will maximise adhesion between a partial coat of tank-sealer and diesel? Will sand-blasting, and/or using salt-water (to create a fine layer of fresh rust for good grip) help?
  2. Our Gas Tank Sealer Kits contain everything you need to clean, prep & permanently seal up your gas tank. The Tank Sealer is impervious to all fuels and alcohol additives! https://www.kbs-coatings.com/tank-sealers.html
  3. Can your gas tank sealer kits be used over a previously coated gas tank?
  4. “I have been working on motorcycles since 1970 and have tried every thing out there. Wish I had found this 44 years ago! Application is easy and the finished product is like nothing else out there. It is like a new coat of steel on the inside of tank. Follow the safety precautions and mask your finished paint well.” -Knucklehead from Spokane, WA Be sure to check out our Gas Tank Sealer Kits.
  5. I have a 200 gallon metal tank. How much of your products do I need? Can you please provide instructions?
