January 27Jan 27 comment_10250 What is the diluted solution ratio for a ultrasound machine? Link to comment https://success.kbs-coatings.com/topic/7443-kbs-cleaner-in-a-ultrasonic-machine-what-is-the-dilution-ratio/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
January 27Jan 27 comment_10251 For an ultrasonic cleaner, most people dilute KBS Klean: 10 Parts Water to 1 Part KBS Klean. If you need a stronger solution, you can dilute KBS Klean: 1 Part Water to 1 Part KBS Klean. If you do not need such a strong solution, you can dilute KBS Klean: 25 Parts Water to 1 Part KBS Klean. Please let us know if that helps and if you have any additional questions. Link to comment https://success.kbs-coatings.com/topic/7443-kbs-cleaner-in-a-ultrasonic-machine-what-is-the-dilution-ratio/#findComment-10251 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
