January 11Jan 11 comment_10222 The coating on inside of motorcycle tank is grey. I have use the KBS paint strip process 3 times. Which did not remove all the paint. I then did the KBS Klean 3 times and did the Rust blast twice. I am still getting pieces of paint when I wash out tank. What should I do, I Dont want to apply sealer yet till i know all lose paint is gone. Link to comment https://success.kbs-coatings.com/topic/7423-paint-removal/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
January 11Jan 11 comment_10223 Yes, all of the loose, old sealer needs to be removed. That is correct. Here is what you can do: Grab a length of chain. Put it in the tank. Put KBS Klean mixture in the tank. Shake the tank violently for 3-5 minutes. Repeat as many times as it take to get the loose, flaky sealer out of the tank. Please let us know what additional questions you may have. Link to comment https://success.kbs-coatings.com/topic/7423-paint-removal/#findComment-10223 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
