Oceanside Joe Posted November 5, 2025 Report Share Posted November 5, 2025 Hi. Do you have any products that can restore, paint, or protect old and faded plastic wheel well liners? Thanks. Quote Link to comment https://success.kbs-coatings.com/topic/7307-plastic-wheel-well-liners/ Share on other sites More sharing options...
KBS Coatings Posted November 5, 2025 Report Share Posted November 5, 2025 We absolutely do have products to paint old and faded plastic wheel well liners. Are you looking for a smooth finish or a texture type finish? Quote Link to comment https://success.kbs-coatings.com/topic/7307-plastic-wheel-well-liners/#findComment-10080 Share on other sites More sharing options...
Oceanside Joe Posted November 6, 2025 Author Report Share Posted November 6, 2025 Ooh. I have choices?! A textured finish would probably hide some of the plastic's defects, so most likely textured. But of course I am curious about the smooth finish now as well. 😀 Quote Link to comment https://success.kbs-coatings.com/topic/7307-plastic-wheel-well-liners/#findComment-10081 Share on other sites More sharing options...
KBS Coatings Posted November 6, 2025 Report Share Posted November 6, 2025 First is proper prep. Clean the faded plastic wheel well liners well with KBS Klean. Rinse. Then let dry. KBS Klean -> https://www.kbs-coatings.com/kbs-klean For a textured finish, apply KBS UnderCoat Rubberized or KBS UnderCoat Asphalt directly to the cleaned plastic wheel well liners. KBS UnderCoat Rubberized -> https://www.kbs-coatings.com/undercoat-solvent-rubberized KBS UnderCoat Asphalt -> https://www.kbs-coatings.com/undercoat-solvent-asphalt For a smooth finish, apply BlackTop directly to the cleaned plastic wheel well liners. BlackTop -> https://www.kbs-coatings.com/blacktop Please review those products and reply with additional questions that you have. Oceanside Joe 1 Quote Link to comment https://success.kbs-coatings.com/topic/7307-plastic-wheel-well-liners/#findComment-10082 Share on other sites More sharing options...
Oceanside Joe Posted November 23, 2025 Author Report Share Posted November 23, 2025 Hi again, I went with the KBS Undercoat Rubberized and absolutely love the texture out of the aerosol. However, I underestimated how many cans I would need and was only able to get 1 1/2 light coats on my wheel wells. Once I order more, what would be the prep needed to continue adding light coats since the current coat will be cured by then? Thanks. Quote Link to comment https://success.kbs-coatings.com/topic/7307-plastic-wheel-well-liners/#findComment-10123 Share on other sites More sharing options...
KBS Coatings Posted November 23, 2025 Report Share Posted November 23, 2025 Are you keeping the surface covered and clean or is the surface exposed to the elements? Quote Link to comment https://success.kbs-coatings.com/topic/7307-plastic-wheel-well-liners/#findComment-10124 Share on other sites More sharing options...
Oceanside Joe Posted November 24, 2025 Author Report Share Posted November 24, 2025 They are sitting under a covered porch after drying. Amazing difference though on these 38 year old plastic wheel well liners. 1. Side by side comparison of plastic wheel well cleaned only with KBS Klean 2. Side by side comparison of plastic wheel well cleaned with only KBS Klean 3. Wheel well just before using KBS UnderCoat in an aeresol 4. Post KBS UnderCoat and looks brand new! Quote Link to comment https://success.kbs-coatings.com/topic/7307-plastic-wheel-well-liners/#findComment-10125 Share on other sites More sharing options...
KBS Coatings Posted November 24, 2025 Report Share Posted November 24, 2025 If the surface has been kept clean, simply apply more coats of KBS UnderCoat with no prep required. If the surface needs cleaned, use KBS Klean to clean the surface, then simply apply more coats of KBS UnderCoat with no prep required. The pictures look fantastic. Thank you for sharing them with us. Please reach back out should you have any additional questions. Oceanside Joe 1 Quote Link to comment https://success.kbs-coatings.com/topic/7307-plastic-wheel-well-liners/#findComment-10126 Share on other sites More sharing options...
Oceanside Joe Posted December 22, 2025 Author Report Share Posted December 22, 2025 I did two more coats on those plastic wheel well liners and they look unbelievably good! Thanks! Quote Link to comment https://success.kbs-coatings.com/topic/7307-plastic-wheel-well-liners/#findComment-10195 Share on other sites More sharing options...
KBS Coatings Posted December 22, 2025 Report Share Posted December 22, 2025 So good to hear! Thank you for letting us know. 👊 Quote Link to comment https://success.kbs-coatings.com/topic/7307-plastic-wheel-well-liners/#findComment-10197 Share on other sites More sharing options...
