Andrew fleming Posted January 14 Report Share Posted January 14 If heat curing is required, how do you suggest curing a entire smoker? 3 minutes ago, Andrew fleming said: If heat curing is required, how do you suggest curing a entire smoker? Quote Link to comment https://success.kbs-coatings.com/topic/6274-heat-curing/ Share on other sites More sharing options...
KBS Coatings Posted January 14 Report Share Posted January 14 How hot do the actual surfaces to be prepped and coated on the smoker get? Most people curing XTC on a smoker start up the smoker, let it get to temperature for 30-60 minutes, and then let it cool naturally back to room temperature. We are looking forward to your reply and assisting you further. Quote Link to comment https://success.kbs-coatings.com/topic/6274-heat-curing/#findComment-8944 Share on other sites More sharing options...
