Kyler Posted June 7, 2024 Report Share Posted June 7, 2024 I’ve got a polished aluminum trailer can I use the product for a clear coat so I don’t have to worry about polishing ? Quote Link to comment https://success.kbs-coatings.com/topic/3099-polished-aluminum-trailer/ Share on other sites More sharing options...
KBS Coatings Posted June 7, 2024 Report Share Posted June 7, 2024 Yes, DiamondFinish Clear can be easily used to clear coat and protect a polished aluminum trailer. Prep Notes: Metals should be freshly polished or sanded to the finish required. For non-ferrous metals (aluminum, copper, brass, etc.), clean with KBS Klean at a dilution rate of 25 parts hot water to 1 part KBS Klean (4% strength) with the use of a very soft non-abrasive cleaning pad. Rinse the KBS Klean solution immediately making sure you do not let it sit on the surface and dry in a way that minimizes any water stains. Complete Application Directions for DiamondFinish Clear: https://www.kbs-coatings.com/diamondfinish-clear-directions.html Please reach back out with any additional questions. Quote Link to comment https://success.kbs-coatings.com/topic/3099-polished-aluminum-trailer/#findComment-5706 Share on other sites More sharing options...
