transam7801 Posted April 6, 2024 Report Share Posted April 6, 2024 I plan to coat the floorpan of my car with KBS BedLiner as an added protection and/or to help prevent road noise. When reading the provided instructions, I see that there's a 8-10 hour cure time recommended before getting into the truck bed to make touch ups. I feel that my use case will be slightly different since I won't have to stand on the coating to recoat. Can you advise what the recommended time is between coats if I don't have to stand on the surface to reacoat (like the underside of the car)? Is there a way to check the coating to ensure it's ready for another coat? Thanks in advance! Quote Link to comment https://success.kbs-coatings.com/topic/3087-bed-liner-time-between-coats/ Share on other sites More sharing options...
KBS Coatings Posted April 8, 2024 Report Share Posted April 8, 2024 For your floorplan, apply the next coat of KBS BedLiner once the previous coat of KBS BedLiner is dry-to-the-touch and does not leave a fingerprint (usually 1-2 hours depending on temperature and humidity). Please let us know if that helps and if you have any additional questions. Quote Link to comment https://success.kbs-coatings.com/topic/3087-bed-liner-time-between-coats/#findComment-5676 Share on other sites More sharing options...
