transam7801 Posted December 11, 2023 Report Share Posted December 11, 2023 I want to use the Bed Liner material over RustSeal on my undercarriage. After reading the instructions, it looks as if I can add the Bed Liner over fully cured RustSeal. I want to be sure I understand what is meant by "fully cured" in this context. Does that mean I'll be able to coat the RustSeal with Bedliner after the approximate 3 hour window passes and the Rust Seal no longer leaves fingerprints? Or do I have to wait the full 24 hours for RustSeal to cure before scuffing and coating with KBS Bed Liner? Quote Link to comment https://success.kbs-coatings.com/topic/3066-bed-liner-over-rustseal/ Share on other sites More sharing options...
KBS Coatings Posted December 11, 2023 Report Share Posted December 11, 2023 Quote Does that mean I'll be able to coat the RustSeal with Bedliner after the approximate 3 hour window passes and the Rust Seal no longer leaves fingerprints? Yes, KBS BedLiner and RustSeal will fuse together if you do this. Quote Or do I have to wait the full 24 hours for RustSeal to cure before scuffing and coating with KBS Bed Liner? Yes, you can also do it this way and KBS BedLiner and RustSeal will fuse together. So, basically, you can pick what works best for you and your application and timeframes. The combination of RustSeal and the KBS BedLiner will give you an incredibly durable surface that is UV stable providing excellent rust protection. Please let us know if that helps and do not hesitate to reach back out if you have any additional questions. Quote Link to comment https://success.kbs-coatings.com/topic/3066-bed-liner-over-rustseal/#findComment-5641 Share on other sites More sharing options...
