Yes, Tank Sealer does adhere to itself well as long as the surface is kept clean before the next coat of Tank Sealer is applied.
Please be sure to not let the Tank Sealer puddle.
The long term performance of any coating is a collaboration between the quality of the coating and the preparation and application of the coating. Please be sure to read through carefully the application directions which will set you up for success and the professional results that you expect.
Tank Sealer Directions Link 👉 https://www.kbs-coatings.com/tank-sealer-directions.html
If you have additional questions, please do not hesitate to reach out.
https://success.kbs-coatings.com/topic/3063-sealing-twice/#findComment-5633
