How to Stop Rust and Prevent Rust
To stop rust, cut it off from the moisture and oxygen it needs. Remove the loose rust, clean and etch the metal with KBS Klean and RustBlast, then seal it with two coats of RustSeal. Tight rust that remains gets sealed in place, so you do not have to grind down to bare metal.
We have moved this guide to our main site and expanded it. It now has step-by-step directions, a comparison of sanding, rust converter and the KBS 3-Step System, and answers to common questions:
Have a question about your project? Reply below and the KBS team will help.
