DougRHoffman Posted October 5, 2021 Report Share Posted October 5, 2021 I purchased a new DeeZee STEEL 40 gal transfer tank to install in my PU bed. I want to seal the tank first. As the inside is " new and clean ", as not used and rusted, should I " blast " it first - to get the etching aspect onto the interior surface, then rinse, dry, and install the sealer, or just rinse, dry and seal coat? Quote Link to comment https://success.kbs-coatings.com/topic/2957-new-transfer-tank-seal-process/ Share on other sites More sharing options...
KBS Coatings Posted October 6, 2021 Report Share Posted October 6, 2021 It is best to use all three steps of the Tank Sealer System for new tanks. The KBS Klean removes the manufacturing residues, the RustBlast etches the new slick surface, and then the Tank Sealer seals it up preventing rust down the road. Please let us know if that helps and if you have any additional questions. Quote Link to comment https://success.kbs-coatings.com/topic/2957-new-transfer-tank-seal-process/#findComment-5383 Share on other sites More sharing options...
