Christie Posted March 31, 2021 Report Share Posted March 31, 2021 Can you tint or add powdered pigment to Diamond Finish Clear? I have some various project where i'd like to add either white pigment, or Hemway's pearlescent color shift powders to my first 2 coats before adding regular Diamond Finish Clear as my top coat. Are there specific brands you suggest or is it not advised at all? Thanks! Quote Link to comment https://success.kbs-coatings.com/topic/2931-tinting-or-adding-pigment-to-diamond-finish-clear/ Share on other sites More sharing options...
KBS Coatings Posted March 31, 2021 Report Share Posted March 31, 2021 We have customers add pigments to DiamondFinish Clear all of the time. Please be sure the pigment you select is 100% dry and urethane grade. Always mix only what is needed as the pot life might be diminished. Please let us know if that helps and if you have any additional questions. Quote Link to comment https://success.kbs-coatings.com/topic/2931-tinting-or-adding-pigment-to-diamond-finish-clear/#findComment-5309 Share on other sites More sharing options...
