March 11, 20215 yr comment_5301 Hi, I applied black motor coater from a pint can on a clean stripped block. And I'm having issues with curing. Some thick spots seem to be still not dried yet, and when I try to heat up the block to test for temperature resistance it gets tacky and when you touch it it leaves a mark. Then when. It cools off it hardens again. Is that supposed to happen? Or is there a breaking process for this paint to fully cure? Link to comment https://success.kbs-coatings.com/topic/2926-motor-coater-not-curing/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
March 11, 20215 yr comment_5302 It does sound like the Motor Coater was applied thick in spots. You can force the remaining solvents (full cure) out by heat cycling. Heat up the block and then let the block cool naturally to room temperature. Do this 5-10 times and you will fully cure the Motor Coater. Please let us know if that helps and if you have any additional questions. Link to comment https://success.kbs-coatings.com/topic/2926-motor-coater-not-curing/#findComment-5302 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
