I have a VW floor pan that I am going to have sandblasted.  After blasting, it has a few places that will require minor weld repairs.  What do you recommend for a weld through - after blasting treatment to prevent flash rusting while the weld repairs are made (guessing two weeks to a month)?  Then, after repairs are made, which products do you recommend progressing through to end up with a gloss or chassis black floor pan?
https://success.kbs-coatings.com/topic/2920-vw-floor-pan/
It is always best to do your welding right after the sandblasting and then do the KBS 3-Step Rust Prevention System on all of the weld spots and just RustSeal on the non-welded, sandblasted areas.
Be sure to handle the parts with gloved hands to keep finger oils off of the surface.
https://success.kbs-coatings.com/topic/2920-vw-floor-pan/#findComment-5284
