carborundum Posted August 11, 2019 Report Share Posted August 11, 2019 I want to spray inside of vertical tubes that are part of a steel gate. Spraying would be best before welding.However, the process could be changed to inject liquid after welding (through vent holes that would be welded shut after injection.) Any concerns due to welding heating the fluid? Quote Link to comment https://success.kbs-coatings.com/topic/2549-toxic-fumes-from-welding-heat/ Share on other sites More sharing options...
KBS Coatings Posted August 12, 2019 Report Share Posted August 12, 2019 The Cavity Coater could burn with the heat from welding, so it would be best to put Cavity Coater in through vent holes and then do the minimal welding after that. Please let us know if that helps and if you have any additional questions. Quote Link to comment https://success.kbs-coatings.com/topic/2549-toxic-fumes-from-welding-heat/#findComment-4617 Share on other sites More sharing options...
