Moe Posted July 25, 2019 Report Share Posted July 25, 2019 Will Diamond Coating work well to protect blued steel? Quote Link to comment https://success.kbs-coatings.com/topic/2508-coating-blued-steel/ Share on other sites More sharing options...
KBS Coatings Posted July 30, 2019 Report Share Posted July 30, 2019 Yes, DiamondFinish Clear will adhere very well to blued steel. Metals should be freshly polished or sanded to the finish required. For ferrous metals, clean with KBS Klean at a dilution rate of 10 parts hot water to 1 part KBS Klean (10% strength) with the use of a soft non-abrasive cleaning pad. Rinse the KBS Klean solution immediately making sure you do not let it sit on the surface and dry in a way that minimizes any water stains. Please let us know if that helps and if you have any additional questions. Quote Link to comment https://success.kbs-coatings.com/topic/2508-coating-blued-steel/#findComment-4574 Share on other sites More sharing options...
