ShawnM Posted July 18, 2019 Report Share Posted July 18, 2019 Does it make sense to use Rust Blast and a rust converter? Would it make a difference in which order they were used? Quote Link to comment https://success.kbs-coatings.com/topic/2500-using-rust-blast-and-a-rust-converter/ Share on other sites More sharing options...
KBS Coatings Posted July 18, 2019 Report Share Posted July 18, 2019 Yes, you can use RustBlast and Rust Converter together. Here are the steps: Clean the surface really well with KBS Klean. Etch the surface well with RustBlast. Then apply the Rust Converter which will leave a nice primed surface. Please let us know if that helps and if you have any additional questions. Quote Link to comment https://success.kbs-coatings.com/topic/2500-using-rust-blast-and-a-rust-converter/#findComment-4548 Share on other sites More sharing options...
ShawnM Posted July 20, 2019 Author Report Share Posted July 20, 2019 Sounds good! Thanks. KBS Coatings 1 Quote Link to comment https://success.kbs-coatings.com/topic/2500-using-rust-blast-and-a-rust-converter/#findComment-4552 Share on other sites More sharing options...
