po18guy Posted July 17, 2018 Report Share Posted July 17, 2018 Due to a handling "error", I damaged the primer/color/clear on a section of exhaust. It has not been cured. Is it best to touch up then cure, or cure what is there and touch up? Am guessing re-spray before cure, but you guys know your product best! Thank you much! Quote Link to comment https://success.kbs-coatings.com/topic/2293-repairing-damage-to-xtc-paint/ Share on other sites More sharing options...
KBS Coatings Posted July 17, 2018 Report Share Posted July 17, 2018 Go ahead and apply some additional thin coats of XTC to fix the handling error before doing the heat cure. Wait 8 hours after the last coat before you do the heat cure. Please let us know if that helps and if you have any additional questions. Quote Link to comment https://success.kbs-coatings.com/topic/2293-repairing-damage-to-xtc-paint/#findComment-4260 Share on other sites More sharing options...
po18guy Posted July 17, 2018 Author Report Share Posted July 17, 2018 4 hours ago, KBS Coatings said: Go ahead and apply some additional thin coats of XTC to fix the handling error before doing the heat cure. Wait 8 hours after the last coat before you do the heat cure. Please let us know if that helps and if you have any additional questions. Thank you very much! Will do. KBS Coatings 1 Quote Link to comment https://success.kbs-coatings.com/topic/2293-repairing-damage-to-xtc-paint/#findComment-4261 Share on other sites More sharing options...
