[email protected] Posted June 4, 2018 Report Share Posted June 4, 2018 Hi, What solvent could I use to re-liquify the tank sealant, in case I needed to seal a pin hole or some other reason Quote Link to comment https://success.kbs-coatings.com/topic/2280-how-to-liquiify-the-tank-sealer-after-setting-up-hardening/ Share on other sites More sharing options...
KBS Coatings Posted June 5, 2018 Report Share Posted June 5, 2018 Once the KBS Tank Sealer is completely cured, no solvents will touch it. KBS Strip can be used to remove it but if you do the tank sealing process correctly, there will be absolutely no reason to remove it. Tank Sealer will seal up pinholes (tip of pin) and if you have holes larger than pinholes, plug the holes first from the outside with NuMetal Epoxy Putty of KBS Patch first and then do the KBS 3-Step Tank Sealing System on the inside of the tank. Your Success is Extremely Important To Us! We want your project to be a complete success so please be sure to read through carefully the following documents which will ensure your success using KBS Coatings. Tank Sealer Directions: https://www.kbs-coatings.com/tank-sealer-directions.html Tank Sealer: https://www.kbs-coatings.com/tank-sealer.html Tank Sealer Kits: https://www.kbs-coatings.com/tank-sealers.html Tank Sealer Application Videos: https://www.kbs-coatings.com/instructional-videos.html#ts Tank Sealer Flow Chart: https://www.kbs-coatings.com/tank-sealer-flow-chart.html Tank Sealer How-To Section: https://www.kbs-coatings.com/how-to-sealing-gas-tank.html Tank Sealer Fix-It Guides found here: https://www.kbs-coatings.com/fix-it-guide-tank-sealer.html Please let us know if that helps and if you have any additional questions. Thanks for choosing KBS Coatings. Quote Link to comment https://success.kbs-coatings.com/topic/2280-how-to-liquiify-the-tank-sealer-after-setting-up-hardening/#findComment-4241 Share on other sites More sharing options...
