Jimmy Mc Posted May 14, 2018 Report Share Posted May 14, 2018 I sealed 2 7 gallon tanks on my jet boat. I would like to seal them again. Am I able to seal a previously sealed tank? Quote Link to comment https://success.kbs-coatings.com/topic/2275-sealing-a-previously-sealed-aluminum-tank/ Share on other sites More sharing options...
KBS Coatings Posted May 14, 2018 Report Share Posted May 14, 2018 What did you use to seal the jet boat tank? Please let us know and we will assist you further. Quote Link to comment https://success.kbs-coatings.com/topic/2275-sealing-a-previously-sealed-aluminum-tank/#findComment-4219 Share on other sites More sharing options...
Jimmy Mc Posted May 15, 2018 Author Report Share Posted May 15, 2018 I used your tank sealing kit. The 3-step kit Quote Link to comment https://success.kbs-coatings.com/topic/2275-sealing-a-previously-sealed-aluminum-tank/#findComment-4222 Share on other sites More sharing options...
KBS Coatings Posted May 15, 2018 Report Share Posted May 15, 2018 Tank Sealer does not stick well to itself. If you want to seal the tank again, you can pour some KBS Fusion in the tank (that has been sealed but has not had fuel put in it), roll the tank around so that all sides are evenly coated and then drain out the excess KBS Fusion. Let the KBS Fusion cure overnight before putting the next coat of Tank Sealer in the tank. Always remember to never let the Tank Sealer puddle of get thick. Please be sure to study well the complete Tank Sealer Directions. If you have any additional questions, please do not hesitate to contact us. Quote Link to comment https://success.kbs-coatings.com/topic/2275-sealing-a-previously-sealed-aluminum-tank/#findComment-4225 Share on other sites More sharing options...
Jimmy Mc Posted May 15, 2018 Author Report Share Posted May 15, 2018 What if fuel has been in the tanks after I initially sealed them the first time?. Can I still use the fusion and then the sealer? Quote Link to comment https://success.kbs-coatings.com/topic/2275-sealing-a-previously-sealed-aluminum-tank/#findComment-4226 Share on other sites More sharing options...
KBS Coatings Posted May 16, 2018 Report Share Posted May 16, 2018 If you put fuel in the tank needs to be cleaned really well on the inside with KBS Klean (remove all fuel residue) and then rinsed and allowed to get bone dry before applying the KBS Fusion. Please let us know if you have any additional questions. Quote Link to comment https://success.kbs-coatings.com/topic/2275-sealing-a-previously-sealed-aluminum-tank/#findComment-4227 Share on other sites More sharing options...
