Bait Painter Posted January 23, 2018 Report Share Posted January 23, 2018 To keep the smell out of the house I would like to dip my lures outside, let them air out for 1/2 hour then bring inside to cure. Temps are anywhere from 30-40 degs Fahrenheit outside. If I did this would it effect the finish on my lures using KBS diamond finish? Quote Link to comment https://success.kbs-coatings.com/topic/2259-kbs-diamond-cold-weather-use/ Share on other sites More sharing options...
KBS Coatings Posted January 23, 2018 Report Share Posted January 23, 2018 When you apply outside of our temperature recommendations (55-82F), DiamondFinish Clear can take much longer to cure. Because it is outside of our recommendations, we have not done extensive testing. Please feel free to test it for yourself and let us know how it works for you. Please be sure to check out the complete DiamondFinish Clear Directions. We are looking forward to you reporting back as to how well this worked for you. Thanks for contacting KBS Coatings. Quote Link to comment https://success.kbs-coatings.com/topic/2259-kbs-diamond-cold-weather-use/#findComment-4183 Share on other sites More sharing options...
Bait Painter Posted January 23, 2018 Author Report Share Posted January 23, 2018 Thank you for the quick response. Will update with the results. KBS Coatings 1 Quote Link to comment https://success.kbs-coatings.com/topic/2259-kbs-diamond-cold-weather-use/#findComment-4184 Share on other sites More sharing options...
