  • 7 years later...
I just bought a can of the Diamond finish.. I recently purchased a 20 yr old boat and the fenders are fiberglass to match the boat. I was going to test this product on the fenders and if all goes well, maybe on the boat top surfaces.
I have used a medium course sander, and a fine sanding block to remove the oxidation from the fiberglass fenders. My question is: can I just use the diamond finish clear out of the can, without mixing with a thinner?
DiamondFinish Clear does NOT have to be reduced to apply. You will prep the surface, mix well, and then apply. Reducing is something that can be done to tweak the finish when that is needed. Most will apply to a test spot in an inconspicuous area to get the application process down pat.
