Coreyd Posted December 8, 2015 Report Share Posted December 8, 2015 After painting my object, do I need to heat treat it before use? and if so , do I heat treat after both primer then color or after primer heat treat and then put color on and treat again? Quote Link to comment https://success.kbs-coatings.com/topic/1909-heat-treat/ Share on other sites More sharing options...
KBS Coatings Posted December 8, 2015 Report Share Posted December 8, 2015 You can put your XTC Primer down and your XTC and then do the heat cure after the last coat is down. Yes, we recommend doing a heat cure for maximum durability and adhesion before putting in to use. Please review the XTC Directions and the XTC Primer Directions and let us know if you have any additional questions. Quote Link to comment https://success.kbs-coatings.com/topic/1909-heat-treat/#findComment-3446 Share on other sites More sharing options...
