My tank is leaking from the front ear when bolted to frame, seems to be pulling in ear and causing weld seam to open up and leak. I read this coating is flexible...after coating it would I be able to bolt that ear to the frame without leaking or will the pulling in that is opening some leak still leak?
https://success.kbs-coatings.com/topic/1868-is-tank-sealer-flexible/
Yes, the Tank Sealer is completely flexible when fully cured. As long as you take your time doing the KBS Klean and RustBlast steps, there is no reason that the Tank Sealer will not adhere really well to your tank and flex with the tank as the tank expands and contracts.
Please be sure to thoroughly read the Tank Sealer Directions so you are confident when you begin your project.
If you do have any other questions, please do not hesitate to reach out.
