Nyalox Brush Used with KBS Klean and RustBlast
Customer Tip: "I found something that works awesome with KBS Klean and RustBlast. It's called a Nyalox brush. It's like those wire wheel brushes you use with a drill, but it's much better for this application. I used the fine grade brush at 1500rpm with KBS Klean and that alone cleaned up most of the rust!I used it with RustBlast and scrubbed for about 2 minutes, it pretty much made the surface perfect!"
KBS Klean: https://www.kbs-coatings.com/KBS-Klean.html
RustBlast: https://www.kbs-coatings.com/RustBlast.html
