RobJ Posted August 19, 2015 Report Share Posted August 19, 2015 Does the XTC primer have to be cured before the XTC paint is applied? Quote Link to comment https://success.kbs-coatings.com/topic/1828-xtc-primer-cured/ Share on other sites More sharing options...
KBS Coatings Posted August 19, 2015 Report Share Posted August 19, 2015 The XTC Primer does not require the XTC is you are happy with the color of the XTC Primer. If that is the case, let it air dry 8 hours and then heat cure it at 350F for 20-30 minutes. If you are putting the XTC over the XTC Primer, wait 8 hours before applying the XTC over the XTC Primer. You can heat cure the entire piece just once after you have applied the XTC Primer and XTC. Please let us know if that helps and if you have any additional questions. Quote Link to comment https://success.kbs-coatings.com/topic/1828-xtc-primer-cured/#findComment-3254 Share on other sites More sharing options...
