albroswift Posted May 12, 2015 Report Share Posted May 12, 2015 Will this product work for 50% Methanol, 50% water mix in an aluminum tank? I am starting to see a little oxidation and have read methanol reacts with aluminum Quote Link to comment https://success.kbs-coatings.com/topic/1780-water-methanol-injection-aluminum-tank/ Share on other sites More sharing options...
KBS Coatings Posted May 13, 2015 Report Share Posted May 13, 2015 Yes, you can absolutely seal up your aluminum tank containing a 50% methanol and 50% water mix with the KBS 3-Step Tank Sealing System. The Tank Sealer is impervious to methanol and water. Please let us know if that helps and if you have any additional questions. Thanks for choosing KBS Coatings! Quote Link to comment https://success.kbs-coatings.com/topic/1780-water-methanol-injection-aluminum-tank/#findComment-3152 Share on other sites More sharing options...
